I want to add to this thread.
I spoke with Dave who owns B&G Performance today for about an hour on the phone. Super nice guy, very friendly, and told me quite a bit of information. Dave worked for Chrysler in the 90s and early 2000s and was one of the original software engineers for the TJ and various other Chrysler powered vehicles.
Because of this, Dave has a wealth of knowledge about these PCMs and how to access them. According to him (and I believe this), he is very well one of the only people in the world who can fully access the PCM on 97-06 TJs (he said he can do it all the way up to 2019 as well though) and have 100% control over them.
Some of the things he mentioned he could do to the PCM are as follows:
- Activate / deactivate SKIM
- Disable post-cat O2 sensors (allowing for cat removal without check engine lights)
- Disable evap system (allowing for evap system removal without check engine lights)
- Disable purge valve (allowing for removal without check engine lights)
- Disable any other emissions
- Change the temperature your cooling fan comes on at
- Fully tune the air / fuel / timing curves
- Change the VIN assigned to a PCM (so you can use it on another vehicle)
- Enable / disable the automatic transmission module on 05-06 PCMs (so you can for instance, use a PCM from a 2005 manual transmission TJ on a 2005 automatic transmission TJ)
The list goes on, but that's just some of what he can do.
He mentioned he can actually tune the PCM even on a stock TJ so that you'll get a bit more performance out of it, and so it will run even better.
You can
send him your PCM using this form and he'll tune it (and enable / disable any features you want) for $399, or you can
buy the software from him for $599 and do it yourself.
The bottom line is that these PCMs are 100% tunable, we can just blame the misinformation that's been spread on the internet for making us believe that it wasn't possible. I'm very, very glad I looked into this further and decided to spend some of my time pursuing a solution to what many considered to be impossible.
This is actually a breakthrough if you ask me. It will allow TJ owners to keep their vehicles on the road for that much longer, but also tune them the way they want. No need for things like Split Second fuel controllers if you want to run boost, you can just tune the PCM directly and be done with it.
I encourage anyone and everyone to share this information and use B&G Performance for all your needs.
You no longer have to believe the lie that our PCMs are not accessible.
