I don't see a HP 44 as anything but a mistake even if it was lower cost. If you think you had a fun time cycling for clearances before, toss one of those pieces of shit under there and then make everyone who recommended it come over and make it fit. They are a few and I mean a scant few rat turds within the same difficulty as getting a Currie HP 60 under there.I want more time, but also take a small measure of pride in saying all the work was done by me. If I order one I'll not be able to say that. There are several folks here that can relate. Although I'm not in their class, conquering another small build objective helps keep my own mind sharp. As I've said before, the real challenge is in maintaining overall balance. I'm still struggling and learning there!
That and they would be ridiculous overkill for 35's and not enough for 37's which makes them a stupid choice for much of anything.
If I had a stock Rubicon 44 out of a TJ laying there on the ground ready to bolt in, I'd still buy and build a HP 30 non disconnect housing and use that with a Super 30 locker. The only bracket work I would do is replace the lower control arm mounts with the ones from IRO. Not because I should but because I can. If fact, that is exactly what I did with the Rubi 44 for mine. (there again though, my build is not based on wise choices)
That and at the end of the day, this isn't really a numbers build, it is a what works best for what I need it to do build and that answer is now and will remain the HP 30.
