Hey guys,
I need some advice on replacing U-joints. I have my axles out and removed the stock U-Joints. I went to press the new spicer ones in and everything went good on first two sides. The second side must have went in crooked and cracked my u-joint and looks like did some damage to my outer axle ears. Here are my questions. I’m running a 2.5 inch lift on 33’s for reference.
What is the best option to replace outer shafts? I found a Yukon gear and axle option I will attach a picture of. Is this my best option? If I go this route should I do both sides? While I’m at it should I just replace all inner and outer drive shafts with something more robust ? Heres pics for reference. Hope this all makes sense.TIA
