It’s not bad. You would need a steering wheel puller, you can usually rent it from most parts stores. Disconnect the battery, positive and negative, let it sit for 10 minutes to de energize the system. Turn the wheel straight ahead. Remove the bolts from the backside of the steering wheel airbag they are 8mm I think, could be 10, it’s been a while since I did one. Remove the bag and unplug it. Take the bolt out of the center of the wheel, use the puller to remove the wheel, the clock spring is snapped in, snap it out and unplug it. Plug your new one in, don’t turn it at all and snap it in place. Reverse the rest of the process. I can do it in 20 minutes.
