It's been easy up to this point. I'm about an hour into the project and likely 2hrs away from completion.This really doesn’t look too bad especially seeing your pics. I may put my new Miller 211 to work on this soon!
Well.... I definitely feel like an idiot now.This has probably been done already by someone but if you are cutting the bottom off flush the piece you remove will fit nearly perfect with some minor adjustments on the top. Just flip it to the top and cap it.
This has probably been done already by someone ...
Yep. That's my inspiration.mrblaine's work on Chris' TJ
It looks like blaine does it the way you were going to in the first place. But I like @MX952 idea. I may try that myselfYep. That's my inspiration.
I'll cut the bottom off tonight. We'll quickly know if its feasible or not.It looks like blaine does it the way you were going to in the first place. But I like @MX952 idea. I may try that myself
Chris, better check on those welds they don't look so goodmrblaine's work on Chris' TJ
Such is life. Sometimes it's hard to see the simple solutions when your mind is fixated on a different path. That's another great aspect of this forum, it enables you to get other ideas and perspectives you otherwise wouldn't consider.You and me BOTH... We were making it harder than it is.
Thanks. Next, I need to join the relocated TB club.Welcome to the club!
If you look at something so long sometimes and outside view sees it easily.Well.... I definitely feel like an idiot now.
A template is a win, better than trial and error I guess. We all learned something!Moving the cap from the bottom will not work. Or, atleast not in a pretty way like @someguysjeep just said.
It is a great template for the new piece though.
Tack then welded the bottom piece. I only went about an inch or so up on the vertical as you can tell by the gap before the grinded tack.
View attachment 233633View attachment 233634View attachment 233635
One down one to go.
