I'll be installing an antirock rear swaybar. https://www.rockjock4x4.com/CE-9900TJR. I spoke with Blaine and he told me that while the arms may need a bit of modification when I outboard it will ultimately work nicely together.What is your plan for a rear sway bar?
The decision to add a rear antirock to the mix was done because in order to cut the upper mounts off the rear axle the OEM brackets had to move also. I was actually planning on running the stock one. As @Midnight LJR would say.... While it's apart I might as well.....
