One more tip on a hood, buy something that uses the standard clear lens so you don’t have to buy special ones. You are more apt to change it if you have a stack in your toolbox. Cheater lens on the inside for us older blind guys. I have been amazed how much better I weld when i put a new lens or change the tip in the welder.
When looking at welders a few tips. Look at the wire spool size can you use the large spool or just the small spool of wire. How much will you use it? Nice to have options. At work the crane shops would pull the spools and put inside to avoid contamination of the wire due to being on the waterfront with all the salt air.
Short answer: no
You're protecting your eyes from an electric arc that is extremely bright. It also emits very harmful UV rays that can burn your eyes and skin in a second
Grab a Lincoln hood from home Depot and you won't regret it
I'm lucky to be able to use a nice Miller from my dad's work. Not sure on model, but it's one of the bigger ones.
But now that I think about it, my "hand-me-down" helmet sucks, been using a work light to see what I'm welding. I'll eventually look into one of the Lincolns, thanks to this thread.
