ranger101
Anyone have any info on installing a new pump into the OEM assembly? Curious how difficult it is.
Just did it. If the bolts come out, it’s easy. If they don’t, be prepared to start cutting for the day.Anyone have any info on installing a new pump into the OEM assembly? Curious how difficult it is.
Exactly. I have a 98 so there were only three things to disconnect, and the assembly is just held in place by a single ring.Which bolts are you referring to? Tank bolts?
Could the leaking check valve in the fuel pump also be causing a 0455 code?The entire fuel pump assembly is not needed, you can replace just the fuel pump itself. The fuel pump also contains the check valve to cure the problem with a bad/leaky check valve causing slow starts in the morning.
This Bosch fuel pump fits all 97-04 TJs. https://www.amazon.com/dp/B000BZL922/?tag=wranglerorg-20
Not likely.Could the leaking check valve in the fuel pump also be causing a 0455 code?
Has anyone tried putting an inline check valve in the line? Are there any reasons not to do this?
Yeah, that has been a concern of mine also, guess I'll just keep cycling the ignition.I can't get this link to work - but it seems an inline check valve is not a strong solution:
https://Jeep Forum/forum/f9/who-has-added-line-fuel-pump-check-valve-684229/index4.html
Wish I would have seen these warnings before, I installed a check valve today but wanted to do some more research to see if it was "the right decision". I had the same issues listed in previews replies, just replaced my fuel pump last month for 98 TJ fuel gauge not working and weeks later this happened. I already got the parts so what the hell, I'll test it out
My setup is using braided Russel fuel lines using aluminum connectors, Russel check valve with a female-female -6 adapter. All my fuel lines after the check valve are new braided lines so if it leaks, it will be on the fuel rail or injectors rings. It definitely has fixed the issue and starts immediately, I'm going for a test drive.
UPDATE
The people who said don't use an inline check valve, they were definitely right! The check valve put too much pressure on the injectors. When I got back from a 5-mile test trip, one of the fuel injectors ITSELF was leaking (not from the top or bottom or rings, it cracked open the injector). Crazy.
UPDATE
How can I contact you regarding these pumps you have to purchase one?I have a quite few what I believe original Mopar fuel pumps new in the box.. if anyone is interested. Just saying.
I just ordered Bosch Fuel pump 67655 and the website shows more in stock. https://www.newparts.com/products?car=42-793-1998&clev=0&hs=1
they have both 67655 and 67659. 230.00-248.00
As an alternative option as parts are getting harder to find, I've been running the late model 05-06 fuel pump (JK pump also fits the same size hole) in my 04 and I've been monitoring AFR. So far everything looks normal. The computer appears to understand the increase in pressure and is adjusting for it.
Order cancellation and refund notice. Your purchase is unexpectedly out of stock...bla, bla, bla. took 3 daysThat website/company has some TERRIBLE review across the net. So, definitely, keep us informed on how your experience is.
Direct drop in?
Got any more info on this?
