Today was suppose to be a victory . . . and yet it was setback instead
I finally got my Ford 6r80 transmission to NP231 adapter in. It looks great and the two piece design with the 3 mounting positions along with the multiple mounting points between the two halves of the adapter will allow me to clock the adapter in any position that I want it to be in.
NP231 Side:
6r80 Side:
This is the life you live when you get custom parts made and your machinist is on the opposite coast from you and a pandemic screws up material delivery as well.
Lets start with the NP231 side of the adapter . . . this one is on me unfortunately. I didn't measure the size of the bearing retainer cap for the NP231 correctly and it's not allowing the adapter to seat flush against the transfer case body.
Now onto the Ford 6r80 side of the transmission adapter and again this one is also my fault. To create the Kubota engine to transmission adapter I had to send a transmission to KubotaSwappers as a reference, I bought a busted 2011 Ford 6r80 on eBay that had free shipping and had it mailed to KubotaSwappers.
He used that same transmission to make the Ford 6r80 to NP231 adapter. Unbenonst to either of us at the time, my 2014 model 6r80 has a slightly different casting around the output shaft housing so it's not sitting flush against the transmission case.
Oddly enough this one is easier to fix as I just have to take a die grinder and remove some of the material on the adapter where it's currently hitting the housing around the output shaft on the Ford 6r80 transmission.
At the end of the day both of the problems are solvable. I took the bearing housing off the NP231 along with the transfer case side of the adapter to the only machine shop I could find where I live and I should have it fixed and back sometime next week, around Tuesday or Wednesday.
As for the transmission side of the adapter I'm going to start slowly removing material from the adapter so it clears the housing around the output shaft of the transmission until I can get it to sit flush with the transmission case.
Again not the end of the world but I had hopes of ordering driveshafts tomorrow and possibly getting my TJ running again, admittedly without driveshafts, this weekend, that will now be postponed another two weeks since I have my kids the following weekend.
I'm getting there, the goal now is to have it all back together before the end of April and on the trails no latter than May but as always I fully except some other issues that I haven't for seen to pop up in the near future as well.
-Grant
