Savvy arms are awesome, synergy steering is a mistakeIn terms of both?
X2 to this.
I like them because they are aluminum, use Johnny Joints (a lifetime joint pretty much), and are adjustable on both ends, which makes setting things up a breeze.
Not saying there's nothing else out there that is good, just saying that the Savvy arms are my go to choice.
Any opinions on Rusty's stuff?
Even skilled welders and fabricators buy pre-made stuff if it's available. It's almost always cheaper in the long run if there is an off the shelf item that meets the requirements. Custom fabrication is generally only cost effective if there are no other options. Factor in learning to weld and buying all the equipment you'd be in deep before you got a passable arm.For the price of better kits you can nearly buy a welder and the materials to make the same quality arms.
Still seems very expensive to me. Sure, the ease of buying the set is there but building arms is very easy unless you need a bend. Also, once you have the joints and you need to build a new set it's very inexpensive. 2 bungs and DOM for each arm is all you need.Even skilled welders and fabricators buy pre-made stuff if it's available. It's almost always cheaper in the long run if there is an off the shelf item that meets the requirements. Custom fabrication is generally only cost effective if there are no other options. Factor in learning to weld and buying all the equipment you'd be in deep before you got a passable arm.
Just put in these Savvy on the rear, will have the front upper and lowers in when I can the next few days.
Double Adjustable, excellent look, nothing I would want on top of that, and on this site had an online coupon!
The big issue with Synergy is that the tie rod ends are in line with the steering links. Whereas Currie bends then to reset the range of motion to match a 4" spring lift. Meaning that Currie allows for more movement than Synergy.Thanks for the discussion and your opinions. I ended up purchasing the Savvy set and a synergy steering kit. Pretty sure the wife will kill me as I didn’t tell her I was buying two parts
I also took the advice of one member who said “ buy once you cry once”.
132,000 miles as far as I know!How much did he get out of his transfer case?
Coupon Code on this forum made them even better, read Fing so many threads i cant find where that was, ha. Can’t wait to get them on up front, but taking the family down to South Padre Island to slay some speckled trout and redfish.They're pricey, but worth it IMHO if you want a control arm that will last the life of the vehicle.
I’ll get them in early next week, and they are worth every $ so far. Maintain andCAs are set forever, ha.
What coupon?Just put in these Savvy on the rear, will have the front upper and lowers in when I can the next few days.
Coupon code?
What coupon?
JF2018 or Savvy2020 codes. Same amount.
Thanks, the JF2018 code is a larger discount.
Yeah, 8% instead of 5% from what I checked.
I used JF2018 was well worth itWhat coupon?
