Yes. If you pull your spring and go to full bump you will probably be in the fenders. Can only give you my best guess based on that photo which is: yes you need the shorter links.I installed the Currie Antirock a couple days ago on my Jeep with a 3 inch lift...my question is “do I need the shorter link rod to level out the arm more?”View attachment 32777
That's what I figured...cool, thanks!Yes. If you pull your spring and go to full bump you will probably be in the fenders. Can only give you my best guess based on that photo which is: yes you need the shorter links.
They are adjustable but it looks like he is fully bottomed out.Those links looks like they are adjustable.
It should not be parallel to the ground it should have a slight angle up but yours looks to be way yo high.
not sure how long the threads are but from the pic I do see plenty of threads left on top and bottom. I would just make sure and if bottomed out then definitely new shorter rodThey are adjustable but it looks like he is fully bottomed out.
Yep I was just getting at that, you beat me to it!Also using the jamb nut he could cut the shaft on both ends grind the treads a it then unscrew the jamb-nut to reset the threads
Yes, fully bottomed out...just ordered the 6 1/2 Link RodThey are adjustable but it looks like he is fully bottomed out.
The rods are threaded quite a bit as you can see on the second photo. The threads showing don’t help @JRUBIC0N unless he trims the ends of the rod. I can only guess that he is asking if he needs shorter links if he is fully bottomed out & not happy with the angle. Otherwise he would just say “should I shorten the links”?
Also @JRUBIC0N, you can either buy new shorter links or you can cut your current ones. This was the stock height links fully bottomed out on my 3” suspension lift (2.5” lift in the front, 4” lift in the rear). I have since purchased new shorter links not shown here.
View attachment 32778 View attachment 32779
You’re fine, you can shorten your current links or buy replacements.Sorry, I meant to only say “should I just shorten the links ?”
I think you got it all covered. As long as both sides stuff to full bump with some extra clearance (remember, bump stops compress on hard hits) the you should be good.I had an opportunity to drive one wheel up a loading dock ramp while keeping the other front on level ground and I can go till my bump stop hits and the Antirock arms clear the body. Also I was able to drive the front down the ramp till the opposite rear raised with out clearance issues plus the Antirock arm to link angle is enough less than 180 to keep it from allowing the link to reverse direction.
Any thing else I should look for? Thanks.
Got a friend who ran one on her jk with no lift for years. It's basically a matter of ensuring the links are the right length for your setup.I'm curious, can I run an AR on a low-lift TJ like mine, or even a stock TJ? Or are these specific to higher lifts?
