I’ve looked up previous threads but couldn’t find a clear answer. I’m looking into an ARB compressor to do tires, and eventually i will run lockers. Is it best to get one compressor to do both lockers and tires? Or 2 separate compressors?
As Jerry stated, the mini ARB is very small and using it to run only the lockers is a very sound way to go. That is our standard go to set up regardless of what method is used to fill tires. The other reason is the big compressors take up a lot of real estate and that sometimes puts them not under the hood on a complex build. That means you are running air lines and whatnot to one or both axles from an atypical location. The reliability of the bigger compressors is also not as good as the little ones.I’ve looked up previous threads but couldn’t find a clear answer. I’m looking into an ARB compressor to do tires, and eventually i will run lockers. Is it best to get one compressor to do both lockers and tires? Or 2 separate compressors?
Got it, thank u. Just wondering what is your go-to compressor for tires? Seems like 2 compressors it be way to go, now just need to find the best for to get for tires.As Jerry stated, the mini ARB is very small and using it to run only the lockers is a very sound way to go. That is our standard go to set up regardless of what method is used to fill tires. The other reason is the big compressors take up a lot of real estate and that sometimes puts them not under the hood on a complex build. That means you are running air lines and whatnot to one or both axles from an atypical location. The reliability of the bigger compressors is also not as good as the little ones.
Are you talking the locker specific ARB mini? CKSA12?As Jerry stated, the mini ARB is very small and using it to run only the lockers is a very sound way to go. That is our standard go to set up regardless of what method is used to fill tires. The other reason is the big compressors take up a lot of real estate and that sometimes puts them not under the hood on a complex build. That means you are running air lines and whatnot to one or both axles from an atypical location. The reliability of the bigger compressors is also not as good as the little ones.
I have the CKMA12 and it works great for both filling up tires and for my air lockerAre you talking the locker specific ARB mini?
Or the CKMA12?
I’ve got the CKTMA12 and it works great. I was planning on two of them in the new build and now I’m rethinking some of that.I have the CKMA12 and it works great for both filling up tires and for my air locker
wats with the T ?I’ve got the CKTMA12 and it works great. I was planning on two of them in the new build and now I’m rethinking some of that.
Twin, oops stuck the t in the wrong spotwats with the T ?
Until it’s a hot day and the ARB passes it’s duty cycle getting 35s from 8 to 26… ask me how I know.I have the CKMA12 and it works great for both filling up tires and for my air locker
The mini, always.Are you talking the locker specific ARB mini? CKSA12?
Or the CKMA12?
You really should if you wind up with the Detroit up front.I’ve got the CKTMA12 and it works great. I was planning on two of them in the new build and now I’m rethinking some of that.
