So, I lifted my jku with the Mopar Fox lift which comes with a spicer front shaft. I also put the geo correction brackets, which makes my caster perfect at about 6 degrees but the pinion is not pointing at t case, so the joint is at a 5 degree angle, instead of 0. Is this bad? I don't want to blow up my t case...
