Do it!!!I’ve always liked the insert tail lights .. are they hard to install and do yours have reverse lights or is that what are in the bumper?
Sure! We might have to go to a drive in liquor store though.Poop! Starting to wonder about my timeline for the re-gear as well. Will wait till it gets closer, but I need to drive around some to break in the gears. Want to grab a beer? Hoping I can leave my RV at the shop for a while so I can drive around a bit.
Mine are on the bumper but there are some with integrated b-up lights.I’ve always liked the insert tail lights .. are they hard to install and do yours have reverse lights or is that what are in the bumper?
I like em... I will let y’all know when and if I do it.. which means I will
Also these are newI like em... I will let y’all know when and if I do it.. which means I will
Thanks
Leave the Scotch at home.I have a fully functioning RV with a fridge. I'll stock up.
Uncle Toms would be a good break in runI have a fully functioning RV with a fridge. I'll stock up.
Have fun!!I like em... I will let y’all know when and if I do it.. which means I will
Thanks
That hole saw bit made my stomach turn but I will get over it
After the first hole the second one is a breezeThat hole saw bit made my stomach turn but I will get over it
It gets easier every time you drill a hole in the body.That hole saw bit made my stomach turn but I will get over it
I used to have a boat...I drilled holes in the hull of that. Once you can do that, putting a hole in the tub of a jeep is a piece of cake!That hole saw bit made my stomach turn but I will get over it
Very trueI used to have a boat...I drilled holes in the hull of that. Once you can do that, putting a hole in the tub of a jeep is a piece of cake!
I haven’t checked, I don’t want to spend any money till I make sure I make it through the pandemic.Have you found out if atlas is still operating?
Do you really want to die without owning an atlasI haven’t checked, I don’t want to spend any money till I make sure I make it through the pandemic.
