Unfortunately I see a major fight over this. I wish my wife would help in my shop more.
RULES for the garage/shop
1. use jackstands and deplete pressure from hydraulic jacks when working under a vehicle
2. get a commercial grade fire extinguisher, they have metal tops, not the cheap ones at walmart. Expect to pay $100 or more for a good one with a current date.
3. Get a FLAME CABINET https://www.amazon.com/dp/B001Q8TSBW/?tag=wranglerorg-20
4. Gloves when necessary, take them off when drilling and using tools that rotate.
5. Safety glasses and Safety shields
6. hearing protection when necessary.
7. dont overload shelves with too much weight
8. use flush cut snips when trimming zip ties, you can gut a fish with a sharp zip tie...
9 a painted garage floor improves light and makes it easier to find those things you always drop
10. do not overload electrical circuits, dont plug a power strip into a power strip or extension chord
11. keep an eye out for bins and hooks for peg board so you can utilize all of your wall space.
12. Good lighting is essential, I just coverted my garage to LED, cost me $300 for 16 bulbs 8 feet long. I still need to convert my shop.
13. Good air compressor is essential to run a small harbor freight bead blast cabinet
14. good solvent tank with safety lid, if it flash fires the lid automatically closes.
15 metal safety trash cans, plastic ones melt if there is a spontaneous combustion fire from oily rags.
16. lots of dunnage for blocking things up if you need it. (boards to set things on)
17. anything with a steel cable can be dangerous, some ropes are good, others are not
18. frayed tie down straps can break, good ones are not expensive
19. use the right tool for the right job, if you have it. a monkey wrench is not a hammer
20. have enough air hose so you can put it where you dont trip on it, because if its laying on the floor,its a trip hazard!
