Unless you have installed higher wattage incandescent bulbs, like 100-120 watts, to replace the factory 55 watt sealed beam headlights, there's no need to install a relay controlled headlight harness. The factory bulbs don't pull enough current to be made dimmer with the OE gauge wiring which is more than large enough for the factory 55 watt incandescent headlights.
And there's especially no need or benefit to doing that with LED headlights which pull probably only 25% of the current the factory 55 watt sealed beam headlights do.
Don't fall for the claim you'll get brighter headlights with a relay controlled harness if you're not running aftermarket bulbs that draw significantly more amps (watts) than the factory sealed beam headlights do.
