Are the arms on the SwayLoc supposed to be parallel so the links are the same length? I’m assuming so since there are no splines and it is what it is, but my links are 9.25” and 10” respectively nkw after second adjustment.
Reason I ask is on two separate wheeling trips I disconnected at the trailhead and afterward my passenger side swaybar bracket was bent out toward the passenger tire. Granted, one of those trips I didn’t get out after a few minutes to make sure it disconnected, but it was of course later on on the day.
So I took both links off and made sure they were correct length (no binding at ride height on flat ground) and actually had to shorten one side and then put it back on and then check the other side and actually shorten it a little bit to get them just right. But now I’ve done this twice and both times it bent that bracket.
The length doesn't matter. What matters is you set the link length with the rig on level ground side to side and grow the links to the swaybar mounts. If you are bending the sway bar link mounts on the axle, then you are not making sure it is disconnected before getting into too much articulation. Or you have a sticking latch which you need to check and it likely going to be from trying to set links by dimension rather than how far the arms are from the link mounts.
