Did you install a lower-temp thermister for the electric fan? If so, what part did you choose?
I installed the Derale cooler after repurposing the Setrab cooler that’s in the grill.
Unfortunately, the Derale cooler is running the transmission hotter than it ran with the Setrab in the grill by 20*+. I initially thought the thermister was failing intermittently, but now I believe it simply doesn’t kick the fan on until my temp gauge shows about 199*, and then the fan is back off around 190* or so.
Also, my current thermister coupler points the thermister down towards the ground rather than up like I’ve seen in all other photos. I don’t know if a different coupler is or a different cooler would be required to fix that. I double checked the tightness of the fittings (I wouldn’t want them any looser or tighter).
