I am running AutoZone radiator now. I know, this is garbage![]()
imo why wouldn’t you change it? No way I’d keep that in there if I’m overheating and have a Mopar in a box.
Intake manifold is right on top of the exhaust manifold and two catalytic converters. Cats are can heat up up to 1000F. I don't think that one needs exhaust leak to get his intake manifold to very high temps.
Fwiw, my true IAT temps are ridiculous from the turbo in my 05/06, and my coolant temps hold up just fine.
And the IAT sensor in the manifold is known to heat soak and read higher than what the IAT would read in the tube for the 05/06.
@TexasTJ2004 did you end up installing a mopar radiator?
You wouldn't need to run all that Rube Goldberg crap if you'd just get rid of that shitty Autozone radiator.Meanwhile got my secondary cooling circle up and running.
Here i have heat exchanger that gets the hot coolant from the engine, and heats up the heat exchanger.
Then the secondary loop with its own separate coolant and electric water pump goes through the heat exchanger, then the standard heater core, then to a additional heater core in front, located near the winch, and it had separate electric fan.
I can activate the electric fan from the cabin, using a switch.
It is really ugly, but it is just the first revision on it.
You wouldn't need to run all that crap if you'd just get rid of that shitty Autozone radiator.
I can't effing believe he installed all that crap instead of just installing the Mopar radiator. SMHCertainly makes logical troubleshooting sense…especially when he has the Mopar on hand.
I had to Google Rube Goldberg. I assume that you refer to this thing.You wouldn't need to run all that Rube Goldberg crap if you'd just get rid of that shitty Autozone radiator.
No you did not need to Rube Goldberg it, all you had to do was rip that shitty Autozone radiator out and install the Mopar. Jeez.
I don’t like to admit that I am wrong, but this might (just might) be a case that is wrong.
I will install this guy with together with new Hayden 2791 fan clutch. Let see what gets me.
Give him a break, it’s just the first revision (oh goody)
I am talking about idling for 50 minutes outside of a place where I take the kid for activities. This with AC and automatic transmission.
Dang. Idling for nearly an hour with the AC on.
I dunno if the new radiator is gonna solve that problem, but hopefully it does. If not, try driving around the parking lot instead if sitting stationary and idling. Or at least raise the idle RPM to spin the fan and water pump faster.
Ya, I saw what you posted. Idling for nearly an hour in high temps with the AC on.My problem is idling with AC.
