In my quest to prepare for the upcoming Moab trip, I have been needing to put together a tool kit to cover the basics in the event of a breakdown. This is my first shot at this particular kit, and I'm sure I will make some changes over time, but here is what I ended up with.
Jeep Tool List
Dewalt 1/2” drive impact
Dewalt impact gun
Dewalt light
Dewalt 20v battery x2
Dewalt battery charger
Tape measure
Flat Screw Driver - Large
Flat Screw Driver - Small
Phillips Screw Driver - Large
Phillips Screw Driver - Small
Standard Allen Socket Set
Torx Socket Set
Quick connect socket adapters for impact 1/2”, 3/8”, 1/4”
Quick connect nut drivers 3/8”, 5/16”, 1/4”
Nut Driver - 5/16”
Nut Driver - 7/16”
Wire Strippers
Wire Cutters
Needle nose pliers
Electrical Tape
Hose clamp remover
Wilson mini sledge
Pry Bar - 18”
Pry Bar - 9 1/2”
Combination Wrench - 21mm
Combination Wrench - 22mm
Combination Gear Wrench - 19mm
Combination Gear Wrench - 9/16”
Combination Gear Wrench - 7/16”
Open End Wrench Set 1/4” - 3/4”
Adjustable Wrench
1/2” Breaker Bar
Rachet Wrench - 1/2”
Rachet Wrench - 3/8”
Rachet Wrench - 1/4”
Impact Deep Well Six Point Socket - 9/16”
Impact Deep Well Six Point Socket - 14mm
Impact Deep Well Six Point Socket - 17mm
Impact Deep Well Six Point Socket - 21mm Impact Deep Well Six Point Socket - 22mm Impact Deep Well Six Point Socket - 24mm
Deep Well Six Point Socket - 10mm
Deep Well Six Point Socket - 19mm
Shallow Well Six Point Socket - 20mm
3/8” Socket Extension - 10”
3/8” Socket Extension - 6”
3/8” Socket Extension - 3”
1/2” Socket Extension - 5”
Socket Reducer 1/2” to 3/8”
Utility knife with extra blades
Channel Locks - W/Teeth
Channel Locks - W/O Teeth
7” Vise Grips x2
Adjustable Wrench
Zip Ties
Assorted Fuses
Extra Relay x2
Lug Nut Keys
2 lint free rags
Bottle Jack
Tool Bags
Brake cleaner
Pb blaster
Anti-seize
Thread sealant
Engine oil
The list makes it look like so much until you see it all laid out on my workbench. almost every single one of these tools was used in the build of my jeep over the last couple of years. My goal, was to NOT have to carry a complete set of tools and instead only compile a list of Jeep specific tools. These all came from my tool collection in my garage, so if this ends up working out well, than I will repurchase most of them so that they are kept in the jeep full time.
My next decision came with trying to figure out how to store these tools. After a trip to Menards, I ended up deciding to go with the backpack tool bag. There are a few things that I liked about this backpack... It has a lot of little pockets to keep tools organized, and it has a leak proof floor in it that would make it suitable for carrying a small amount of auto fluids. I didn't end up with enough room for the Dewalt power tools, so I just used an old Dewalt bag for those. Here is the backpack (I also got the smaller bags for sockets and things that you will see in the first photo):
And so far, I think this is my full loadout on the Jeep:
In order from left to right..... Portable Air Compressor - Recovery Straps - Air Compressor Supplies/Tire Repair Kit - Tools/Fluids - Power Tools
I'll add a personal size cooler as well.
I plan to keep this stuff behind the front seats and possibly on the rear seat.
Are you guys aware of a cargo net that would cover that area well?
Jeep Tool List
Dewalt impact gun
Dewalt light
Tape measure
Torx Socket Set
Nut Driver - 5/16”
Nut Driver - 7/16”
Wire Strippers
Wire Cutters
Needle nose pliers
Electrical Tape
Hose clamp remover
Wilson mini sledge
Pry Bar - 18”
Pry Bar - 9 1/2”
Adjustable Wrench
1/2” Breaker Bar
7” Vise Grips x2
Adjustable Wrench
Zip Ties
Assorted Fuses
Extra Relay x2
Lug Nut Keys
2 lint free rags
Bottle Jack
Tool Bags
Brake cleaner
Pb blaster
Anti-seize
Thread sealant
Engine oil
