I can't speak for all of the options out there, but if your Jeep came from the U.S. it is (probably?) not spec'd for DRLs. The 3 pin headlight harness doesn't get any power until the light switch is turned on, so DRLs won't get power through it.
I run these cheap-ish LED/DRL combos I got off Amazon — they are such an upgrade from OEM. Great light, sharp cutoff, super easy to adjust. The DRLs had a separate lead. Now being the impatient person that I am, I could not locate a key-on 12v source under the hood, so had to tap an unused spot in the fuse block and run it out through the firewall to a terminal block I put under the hood. Minor amount of wiring, but now DRLs come on with key-on, and work as front indicators as well if you tap the second extra lead into the indicator wire going to the turn signal just beneath the headlamp.
Wow — I paid$87 for these two years ago. They gone up.
https://www.amazon.com/gp/product/B00WM3WDXA/?tag=wranglerorg-20
EDIT — I'm 99.99% sure these are the exact same ones. Way cheaper.
https://www.amazon.com/dp/B08NXC9549/?tag=wranglerorg-20
