In the past few months, I've acquired a number of the M18 Fuel tools from Milwaukee. The biggest battery I have is the 5ah version, along with a couple 3ah and a 2ah. After following this thread, I think it might be a good idea to get at least one larger one. Based on
@mrblaine's comments, it sounds like that maybe should be the 9ah battery.
I have a question. When it comes to charging the batteries, what procedure do you folks use? Do you charge 'em just prior to needing them, keep them partially charged and monitor when they need to be recharged, or keep them on the charger 24/7? My only concern about the latter option would be the (perhaps unfounded) fear of the risk of fire.
And on the subject of Milwaukee tools, I've run their corded tools forever. Three days ago, my 23 year old angle grinder finally failed. Sounds like the gearbox is gone. So, I picked up both an 11 amp corded replacement (for the garage), as well as the M18 Fuel version for "field" work. An hour into using the new corded one, it starts binding up. Did it several times. Thinking it might be overheating, I let it cool down for a couple hours before using it again. Within a few minutes, it all but locked up. I returned it to the store and exchanged it for another. If it fails, I'll look into buying an older used one. I'm also going to look into having my old U.S. made one rebuilt.
