T-Shirts
Order your offical Jeep Wrangler TJ Forum t-shirt today!
Click here to order!
Jeep Wrangler TJ Forum T-Shirts
Mickey Thompson tires don't measure a true 35 inches
mrblaine
Crew Member
Quail Valley, CA
I’m sure if I took the the weight off I could muster up 34,but I got a deal on these tires,just would like to get a more truer to size 35,but they are really great in mud.
Is there something wrong with your tape measure where it ceases to function horizontally?
You won't get a "true" to size tire on there that will ever give you the loaded height that matches the numbers on the sidewalls, never.
Reactions: Zorba
Zorba
"The Veiled Male"
Merritt Island, Fl
He isn't using a tape measure, he's using an "App" on a smartphone. Everybody knows smartphones only work vertically (as evidenced in the ROTM thread each month!)! :D ;) :ROFLMAO:
SvtLdr
Search Engine Certified Mechanic
NE Indiana
If you got a good deal on it and you're happy with it because it gets the job done and leaves a smile on your face, then does size really matter? Asking for a friend...
LONGJP2
Illinois
If you want the true effective diameter, measure from a good flat paved surface to the exact center of the hub, and multiply X2 - at whatever tire pressure you normally run.
Might want to add that effective diameter is what you want when using a gear calculator like Grimmjeeper.
Reactions: Zorba and jjvw
Moglocker
Moglocker
Missouri
I did it before left the house,in tenn now I’ll measure the tire off the Jeep,I bet it’s 34ish,I sure with they didn’t stop the mtr,looks like a true to size tire,and they are supposed to be good on the rocks,out west will be the first place we’re heading when we retire soon!
  • Face Palm
Reactions: deadbeat son
mrblaine
Crew Member
Quail Valley, CA
You're not listening. It is not possible to put on any tire and have the loaded height match the sidewall numbers. That is not how it works, at all.
andy29847
For actual sizes....
Moglocker
Moglocker
Missouri
I get it Blaine,when I get home I’ll measure the spare on the back.a lot of 35s mount up larger then these,just thinking aloud,no biggie,these are really great in mo mud,they are just really on the smaller 35 side,they won’t last forever being drug behind a motor home,then it will be time for something else,I’m definitely getting beadlocks ,trying to decide what to put on them.I could even sell these,who knows -what is your tire of choice?thanks-jeff
Woodrow
Oregon
Stop being a dumbass and measure it horizontally.
Yep. For speedometer purposes this should be the right. For fender/body clearance too. I feel your frustration though. I don’t get why tire mfgs don’t build tires to the specs on the sidewalls (a 35” diameter tire seems like it should measure 35” in diameter flat on the ground when mounted on a rim).
Fishtaco
TJ Expert
Perth AU
How to measure a fitted tire horizontally:
Buy some 1 1/2" by 1/8th" flat bar, weld up 2 flat 90 degree right angles like a square but x 2 then add a middle adjustment lock/hold bracket , lock new tire measuring devise between front and back of tire horizontally roughly in the centre and then measure inside to inside of your new handy work lol :)
Or get 2 midgets to hold a square each against your tires and then measure the inside> < Lol
