Wow, can't believe I missed this thread! I think i breezed by and thought it was just a stocker or something. Holy smokes its a fantastic build, and CLEAN AF. YOu have a beautiful rig there
@Midnight LJR. Can't wait to hear how i performs offroad too.
@mrblaine rarely are things as easy for me as you describe them. I like what you did here to clearance the tub rail to the exogate hinge. It looks like you didn't use the exogate plate that goes over the armor. Did you do anything special as far as reinforcement of tub?
@toximus mentioned there is quite a bit of tension in the rub rail as you bolt it down, did you have to do anything special to get the radius to match the armor so perfect? I imagine that if you try to pull the radius in with that single last bolt it might just bend the tab? Thanks for your help, this is exactly what i was searching for, how to make the rub rail look clean with the exo hinges.
