Snapped off the bolt for the motor mount on the frame side. I try to tigthen it too much with an impact. Would a bolt extractor work here? Also does anyone know the size of the bolt? P
If it’s cross threaded you will have to drill it out or weld a nut to it. If it wasn’t cross threaded you should be able to turn it out with some pliers.
If you don't have a welder carefully file or grind flats on the remaining bolt to allow locking pliers or even a wrench to fit on to it and unscrew. It really helps to take a second and file flats so you have something to get a bite on. Once the bolt breaks it normally isn't in there too tight so that's a plus.
