There is not much gained by using a 232 crank is there?
I found the number one con rod was bent at some point, likely hydrolocked. That morphed into a mini stroker.
'72-'79 AMC 232 crank (3.5" stroke), 677cp pistons .020" over, 4.0 rods resized, mopar 229 cam and lifters, edelbrock head, HS rockers, SB pushrods, rollmaster double roller, mopar MLS head gasket, mopar standard pressure oil pump, MORE engine brackets and mounts.
Total displacement right at 250ci.
Quench ended up a little tall at .050".
Static comp will be around 9.5:1, dynamic should be 8.2:1 so it'll be a premium fuel motor. No idea what power output will be, but playing around on desktop dyno it might net me an extra 20hp and 50ftlbs simply because of the higher compression and air flow.
