Passenger side lower shock bracket broken
Sinnbad
Tabernacle, NJ, United States
I have a 2001 TJ. I was changing the brakes the other day and saw that the lower shock bracket was about to rust off. I was driving it and it broke off. It’s the bracket that holds the coil spring.
Do you anyone know where I can find a replacement bracket that we can weld back on? Thanks
I will try to include a picture when I get home. It’s the lower bracket where the shock mount.
The only place you'll be able to find that bracket is on a new axle housing.
Of course if you have welding skills you could cut one off a used axle housing at an auto wrecking yard. If you know a good fabricator, I'm sure they could also fabricate something as well.
However, I've never seen anyone just sell the bracket alone. Anytime I've seen it, it's part of a new axle housing.
