YikesJust purchasing them is hard. waiting on a 3rd quote now but getting close.
It doesn't, but if the scrub radius is determined by the relation between the ball joints and the contact patch then you need a large amount of positive offset on Currie axles to get the ball joint anywhere close to being inside the wheel (if that's ideal). If you are running that much offset then this is where axle width comes into play. You need more to compensate and keep the tires from hitting shit. My point was merely that these should be compared to other aftermarket Dana 60 axles. It would be very hard to duplicate the scrub radius of a stock jeep with stock wheels running any of them, unless they are close to full width.How does WMS affect your scrub radius
My intention was not to defend the company or their business practices. I understand even a small percentage is a sizable number of people, given all the jeeps out there.I'm not sure you understand scrub radius.
I install 20,000 dollar sets of axles with a reasonable frequency. If I can't get the info I need to inform someone considering them of the drawbacks or lack thereof, that is clearly an oversight on someone's part.
Maybe that's not what I said, but that is what I meantOne could extrapolate that given a large enough diameter tire that the axle would need to be wider to accommodate interference issues with suspension and frame given a reasonable amount of back spacing to achieve a tolerable scrub radius. That isn't what he said though.
I am because they come standard on Currie axles, but now you're just being silly....Yeah I guess so, I wasn't picturing the whole setup, just the axle.
Sounds like he'd be money and time ahead to just swap to one of these portals so he can run stock suspension with zero problems or bump steer. I mean, he's already got F450 outers, so he's probably part of the .01%, unlike everyone else with just 250 or 350 outers...
If one cares to be picky, Currie hasn't used an F-450 knuckle in a very long time. They do however, use their beefed up version that they "make" themselves. I don't disagree though.I am because they come standard on Currie axles, but now you're just being silly....
What does "make" mean? They contract out their design to a different shop to produce?If one cares to be picky, Currie hasn't used an F-450 knuckle in a very long time. They do however, use their beefed up version that they "make" themselves. I don't disagree though.
That design seems to be a bit different at the knuckle. Portals would be bad ass. No question. I am just wondering if adding it to the end of a conventional axle is a good way to go?
I know that but didn't think it was meaning full for the discussion. I thought they are just machined to accept the high steer arm, but could be wrong about that. Does that mean these won't fit? :If one cares to be picky, Currie hasn't used an F-450 knuckle in a very long time. They do however, use their beefed up version that they "make" themselves. I don't disagree though.
I think they are Volvo portals. Not positive on what out of.That design seems to be a bit different at the knuckle. Portals would be bad ass. No question. I am just wondering if adding it to the end of a conventional axle is a good way to go?
I beg to differ. In the South it’s become common to run the super kingpin stuff and the magnum knuckles from Crane.05+ is a different beast, there are substantial differences, but not many people run the 450/550 05+ stuff
Remember this is a wrangler forum, if this were pirate or irate I wouldn't say what I said, but how many build threads on here have you seen with guys throwing $2k+ at inner and out knuckles because a stock 05+ knuckle setup wasn't enough for them besides your own?I beg to differ. In the South it’s become common to run the super kingpin stuff and the magnum knuckles from Crane.
wish i would have.but how many build threads on here have you seen with guys throwing $2k+ at inner and out knuckles because a stock 05+ knuckle setup wasn't enough for them besides your own?
They have actually never fit but they can be made to.I know that but didn't think it was meaning full for the discussion. I thought they are just machined to accept the high steer arm, but could be wrong about that. Does that mean these won't fit? :
https://www.shop.blackmagicbrakes.c...Kit-w-Master-17Rims-CURRIE-BBK-NEW-MASTER.htmKicking myself for not getting them when the price was lower. Still on my list though.
So do the Currie knuckles use theThey have actually never fit but they can be made to.
Is that what I’m going to use?They have actually never fit but they can be made to.
because JK C's are just as crappy as the TJ 's are. and 2k to fix the mistake is cheaper than 8-10k to swap the axle again.
Yes, we have to open up the center bore to fit the register on the unit bearings. I did a few sets, then discovered there was some consistency issues with the U/B's and now try to do them to fit or from an actual measurement. I've still got rotors that don't fit from that fiasco.Is that what I’m going to use?
Don't know. All the stuff we do is adapted so the TJ booster can handle the work and once we can lock up 40's, do we actually give a shit?So do the Currie knuckles use the
caliper mounts set up for the larger F450 rotor or do they use the F250/350 brake setup. Or am I talking out of my ass
Do you have a specific part number for that unit bearing. They still don’t have it right on the spec unless 8 x 6.5 will work, your site says 5 x 5.5.Yes, we have to open up the center bore to fit the register on the unit bearings. I did a few sets, then discovered there was some consistency issues with the U/B's and now try to do them to fit or from an actual measurement. I've still got rotors that don't fit from that fiasco.
