While going up a easy trail (Rouse Ridge in Southern California) my buddy behind me gets me to stop because my rear shock is dangling and not attached to the axle. I get out and check it out. The bracket ripped and sheared in half. It didn't break at the weld but in the middle of the bracket. Half of the bracket is still attached to the axle and the other half to the shock. Thankfully I was able to easily remove the upper bolts (thank goodness for CA TJ) for the bar pin of the shock and remove the entire shock so that I could finish our run to the top of Thomas Mountain.
With that said, I have a couple questions. It looks like a very easy fix. I have found a couple options for new brackets. See below.
It looks like the added a relocation bracket on the driver's side (the side that broke) and it is a completely different bracket on the passenger side). Are these relocation brackets any good? If not, I probably should remove the passenger side bracket also since it is pushing it away from the axle also.
Also, since I am doing 1 side should I do the other side? I notice it is not he stock bracket on the passenger side, so it must have been replaced at some point in the past but all it is is 2 metal plates not like the stock one which is essentially a U bracket. Please see picture.
I am finding 2 different brackets. Some say for Dana44 and others just say for TJ. From what I understand the TJ Dana 35 and 44 have the same size axle tube right? Isn't it 2.62 diameter? Some of these brackets say for 3 inch axles. Please advise.
Is this a simple job for me to attempt with my buddy who is an amateur welder? If the angle or location is slightly off will it have bad results? If so, I can pay someone to weld it but I thought this might be a good opportunity to start to learn how to weld.
Curry Bracket Pair (doesn't specify an axle type)
https://www.quadratec.com/products/CE-7020.htm
Teraflex (specifies Dana 44 and Dana 60)
https://www.quadratec.com/p/terafle...7-06-jeep-wrangler-wrangler-unlimited-tj-dana
Warrior Products Pair (says for all axles)
https://www.quadratec.com/products/92000_000.htm
Crown Automotive Pair (for 3" axle)
https://www.quadratec.com/p/crown-automotive/weld-shock-mounts-3-axle-tubes
Rubicon Express (doesn't specify an axle)
https://www.quadratec.com/products/16301_4462.htm
