If anyone is wondering, my sliders weigh 45.5 lbs each.
But, do you have stickers?!!
I have a set of the Savvys sitting in the garage, If I didn't I like the BFH sliders 2nd. I honestly think you could sell a good number of these.
I couldn’t handle watching the install on a dirty Jeep.
They look good though.
Is there any other way?
I never saw any dirt on the Batmobile.
They are there for anyone to make. Blaine helped me with the design of these, including the rub rails, followed by a small team effort to get the CAD file made for a fabricator, and then the fabrication of the base rockers to build the rest upon.
All you need is a hunk of cardboard and be willing to fold in your Jeep's pinch seam to get started with them. The rest is just layout.
Once I get the rear stretch done on mine, I will be replacing my Savvy sliders with the DIY mini boatsides.
I’ll buy the takeoffs!![]()
It will be a while, but they will be the mythical hardcore Savvy slider that never was. They are going to be trimmed up front for highline fenders and also have a full length steel slider.
The boatside aspect.
Why?
Put another way, they revert back closer to the original design that GR did for me on the Viking rig, the first set of which is on it.Compared to a normal rock slider, the mini boatside increases the ground clearance of the body by removing the corner under the door.
The mini boatside we built is very similar to the GenRight mini boatside, except that ours does not have the giant tube step to get in the way of the rocks. The other way ours is nicer than most is that I copied what Blaine designed for Savvy by adding the slight over-bend and the slight secret bend under the door to force a tight fit onto the body.
Another detail that is missing from the BFH video would be the use of a large aluminum backer plate inside the door opening intended to sandwich the body sheet metal between the slider and the backer to create a tight unitized structure.
The idea behind these mini boatsides was to take the GenRight mini boatside, remove their clutter, and add in as many Blaine details as we could.
This was the inspiration from one of Blaine's builds a few years ago.
The Savvy aluminum rocker is 3/16" 6061t6 aluminum.
