that pic up there, post 89.............faget about it.
sometimes 1st ideas are lame and it takes some trial and error to fix the nonsense. anyway i really didn't have to offset the sending unit. this posed several issues with fitting in and out of the cell without disassembling it and lengthening the wires to connect it.
it finally dawned on my dumb ass, i don't need to offset it to fit the width ..............there is more than ample length. so i pulled off my jimmy rig bracket and just mounted the dam thing to the side of the can, instead. now it fits in through the dam pump ring and the wires reach as they did b4.
since the sending unit gizmo does snap into it's bracket, and the tabs protrude a bit it needed a standoff from the can. i cleaned up a couple poly slugs from the hole saw, left from drilling the roll over vents in the cell.
this should work betterer-er.
