Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
No, not where the frame bends up for the rear wheel arch, they are pushed forward into the lateral bend right before the belly skid. You could easily lay out the mount, find the center of the mount, cut the frame there, add a 4" section, and move the frame back that way. Keep the rear of the mount marked if you wish and that will put one end of the frame splice inside the C channel of the mount for extra reinforcement.
A couple of inches won't hurt. The TJ arms are shorter than I would like by about 2" and you could easily use the TJ Unlimited arms which are 2" longer. That would automatically get you some of what you are after.
I cut in front when they are already installed. I cut other places when starting from scratch with a new install that includes a stretch.
Not saying it can't happen, but I want to see 102 in a TJ with a tank under the back. I've done it, I won't do it again and I doubt that folks will go to the lengths I did to get that.
This is what the top looks like after we customized the crap out of a tank.
That was pushing and tweaking everything possible to get the front and back as far apart as possible.
You as always do some awesome work.
I'd looked at the idea of trying to do a recessed fuel cell like that and I don't have your skills.
Thanks for setting my straight on my misunderstandings. This really gives me room for thought and ideas.
What about on the front? I think I remember you saying it could be made a little longer without any issue? Can those brackets also be moved a little?
