Hello All!
How would you pick between two adjustable hydraulic shocks with overlapping ranges assuming all other things with the exception of length being the same?
I'm looking at 2 sets of shocks where one is for 1-3 inch and the other is 3-4.5. My LJ is only going to be lifted to 3 inches.
Here are the specs for the following two shocks:
1 - 3 inch
1 - 3 inch
- Item Length (Extended): 23.54"(Front), 21.42"(Rear)
- Item Length (Collapsed): 14.60"(Front), 13.86"(Rear)
- Travel Length: 8.94"(Front), 7.56"(Rear)
- Shock Rod Diameter: 0.71"
- Piston Diameter: 1.42"
- Tube Diameter: 2.28"
- Item Length (Extended): 25.11"(Front), 23.38"(Rear)
- Item Length (Collapsed): 15.39"(Front), 14.84"(Rear)
- Travel Length: 9.72"(Front), 8.54"(Rear)
