I did not do that, just lots and lots of turning the wheel and once I started it I only ran it for short periods and went back to turning the wheel with the engine off.If you aren't bleeding them by turning the pump pulley with something like an air ratchet to make sure there is absolutely no air in the system before you start it, you likely smoked the ring and rotor. It will progressively get worse due to the pits from cavitation that it will make noise at lower and lower rpms until it does it all the time. The high performance pumps have zero tolerance for cavitation.
