made a little more progress today. got the steering linkage all torqued and pinned (minus the frame end TB, might beef/backbone that more).
now i trimmed that pitman after adjusting the throw hole. it gave me about an inch i can scoot the axle forward the struts will take it......all i need to do is relocate the frame side TB mount again.
but i'm gonna pass here i think, it's all set and guestimated for what it is not whats an inch away 1st. and second i don't think i'll be going HA, and might jump right to full hydro if/when this gear dies on me. so not shoving forward means i can keep all that underneath. last is i'm close to the limit of my joint extension from the upper link shaft. any more and it'll need lengthened/replaced.
torqued in the front DS. it's got room to compress and my swing arc is nice and tight now so it only needs to reach down to full droop without droppin out on me and i'm good for now.......if it won't reach or when this 1 shits out i'll put a Woody in.
plumbed up and ran the OX locker feed into the cab.
i could dick around and set this all up on a solenoid and have push button power control. but there's something to be said with the pneumatic switch Ox provides it's cheap and simple. hose, valve, pressure that's it. so i'm gonna go with it for now.
Jensen Bro's came through for me, they got those MA bushings to me today.... from Utah IIRC. TY.
also got the plug for the prop valve, that's in.
just need the rest of the brake pieces parts. then i'll swap the MC when i do that.
got the struts fully mounted. it's all there, all hooked and now tomrw i'm gonna cycle it all again....if i'm good, i'm ready for charging.
