Well things are looking different around the Jeep. It doesn’t look like much but getting thing just right takes hours.
tomorrow :
ATF, and figuring out if I have the right transmission mount and rubber mounts too
Yes I did and I’ll be glad so share , but there is a thread already that @Jerry Bransford and @mrblaine listed the needed information that is much better than my list. Check theirs thread out.
What is the gear ratio you will be running ????
Just a little advice. Take into a lot of thought about the ratio. If you want to travel road as well as off road 4:10 ratio is next to perfect.
If you use your Jeep just for off road then 4:56 or 4:88 will work great.
Trying to drive a 3 speed trans on road with 4:88 gears you will travel top speed around 50 to 55mph. Because of high RPMs.
