There are no holes in the canopy legs to stake it down?
what canopy is that? Mine wont fit there.
Thanks for that. I will measure mine too.It is an older (about 3 years) Wally-mart Ozark 10 x 10 vertical leg canopy (it actually measures closer to 9.5 x9.5 when set up)...
With chinese/Wal-Mart stuff; you basically pays your money and takes your chance's... this one was like $89 on sale.
Edit; Ozark trail 2014
WMT-1010A/30183
Barcode 17427 01256
...Just measured it; its approximately 48.5 " long/tall in the case/carrier...
Enjoy!
Dawghouse, What is the measurement from the top of your trailer deck to the bottom of the tent mount? if you don't mind? I have the same set up, and am considering lifting the bars that the tent bolts to about 4 inches, and I wanted to know if it would look the same as as yours.This is how we camp. Pics from Pickett State park in North East Tn last year in Nov.yours
View attachment 31962 View attachment 31963
I will have to check to make sure. I want to say the verticals are 36" tall from the top rail. This puts the base of the tent at 6ft from the ground. I needed this height for the annex to work right. The rail from the bed is 16" I think. I made this to retrac down 10" when traveling to cut down on wind. And raise up 10" for setup. Here is a pic with it retracted down.View attachment 31965
Oh wait never mind. You actually have the sb trailer. I have the same set up but on a utility trailer so I can haul my quad. It doesn't quite fit. I need another two inches, but 4 would be optimal for scaling. Although making it adjustable intrigues me. Here is mine for reference.
I used 1-1/2OD square stock for the uprights and 2"OD square stock for the risers. To assist in raising the bars I installed 4 60LB struts at each corner and spring loaded pull pins with weld bungs. I have to use straps at each corner to retrieve it back down. Mainly because of the struts.
Do you have the Smittybilt RTT?
mmmm ok so you changed up as you needed more Horsepower ?? :eusa_doh:lolThis is one way my wife and I use to camp. Can really get into some real remote country and great fishing!
:meparto:mmmm ok so you changed up as you needed more Horsepower ?? :eusa_doh:lol
