chill_RN
Sweet! I’ve been looking for something like this for awhile. I may give it a try if you like it that much.It uses screws and holes already in the Jeep it took me an hour to put it in.
How hard is it to mount the rear cargo rack? Did you have to do any type of drilling?
Can you post a good pic of the mounting setup?It uses screws and holes already in the Jeep it took me an hour to put it in.
Uses one of the roll bar bolts and the silver bolt they provide you use the hole that leads through your hole thats already there on top of the rear wheel wellCan you post a good pic of the mounting setup?
I really can’t think of a complaint with it. I use it all the time. And if you need the bottom shelf to have a little more room just add some washers to the bolt and move it up a few inches. I’ve laid down on top of the shelf before (while working in the Jeep or something it’s not a comfortable resting place) and it can hold some weight.Sweet! I’ve been looking for something like this for awhile. I may give it a try if you like it that much.
Thanks!Uses one of the roll bar bolts and the silver bolt they provide you use the hole that leads through your hole thats already there on top of the rear wheel well
I assume it’s this one where there was a drain plug?Uses one of the roll bar bolts and the silver bolt they provide you use the hole that leads through your hole thats already there on top of the rear wheel well
Correct
Have you looked into this slide out storage tray that will fit under the rear seat ?
https://www.ajaxtoolsupply.com/huma...VVaKzhdpcw5Bs_rDRHlrct6mEDGE5dvBoC0agQAvD_BwE
No brackets for the tray or anything to raise the back seat....Does that come with brackets or anything to raise the back seat?
Thanks for posting these pics. I have been looking at that Hooke Road rack for a while now and was not able to see the mounting brackets. For the price, looks like you can't beat it. My only issue is that I want to mount it up higher so it will clear my Dometic Fridge on the slider but it appears as though modifying those brackets should not prove to be difficult. Thanks!!Uses one of the roll bar bolts and the silver bolt they provide you use the hole that leads through your hole thats already there on top of the rear wheel well
Just go to the hardware store and buy like 20 washers and put them under the brackets. Bolts are plenty long enough.Thanks for posting these pics. I have been looking at that Hooke Road rack for a while now and was not able to see the mounting brackets. For the price, looks like you can't beat it. My only issue is that I want to mount it up higher so it will clear my Dometic Fridge on the slider but it appears as though modifying those brackets should not prove to be difficult. Thanks!!
https://tuffyproducts.com/products/...7-1987-1995-wranger-yj-1997-2006-wrangler-tj/
This one has provisions for mounting the seat above the drawer if that is what you are looking for.
What is the clearance under the rack as-is?Just go to the hardware store and buy like 20 washers and put them under the brackets. Bolts are plenty long enough.
