DavidBT TJ Addict Original poster Supporting Member Joined Jun 10, 2022 Messages 1,393 Location South East Arizona May 20, 2023 #1 I picked up a Blue Ox towing base plate and Blue Ox tow bar off Craigslist today. They came off of a 05 TJ, which I have. I would like to ask, when flat towing your TJ, what brake system are you using? I will be towing it with my 1500 Ram Big Horn.
NskLJ TJ Addict Supporting Member Joined Oct 19, 2021 Messages 2,390 Location Long Beach/ Colorado May 20, 2023 #2 This is the system I use, if you raise the rear seat 1” with spaces the control will mount under the seat. Fully self contained hookup and go, disconnect the hitch and drive the jeep. https://www.campingworld.com/roadma...6wbAK9IX0Wrb3qnHRCRoCqc0QAvD_BwE&gclsrc=aw.ds Reactions: DavidBT
DaveC TJ Addict Supporting Member Joined Jan 3, 2019 Messages 2,178 Location Gilbert, Arizona May 20, 2023 #3 This is what I use https://www.amazon.com/dp/B00IK56OC0/?tag=wranglerorg-20 Last edited: May 20, 2023 Reactions: DavidBT
bobthetj03 Daily driver Supporting Member Ride of the Month Winner Joined Feb 3, 2017 Messages 15,336 Location Clearlake Ca. May 20, 2023 #4 This is what I ended up with. https://rvibrake.com/products/rvibr...Cic7-bjn4SGsxL8tJuEhJ1vKkwIstY2hoCxwUQAvD_BwE
MOBDOGG Member Supporting Member Joined Nov 12, 2017 Messages 30 Location Puyallup, WA, United States May 20, 2023 #5 Using Blue Ox
GregBelleville 99 4.0 32rh Supporting Member Joined Sep 19, 2022 Messages 1,576 Location Anaheim, CA May 20, 2023 #6 Not trying to hijack this thread, but would the set up be similar or completely different if I wanted to tow with an SUV?
TheBoogieman Disturbed Supporting Member Joined Jan 1, 2019 Messages 16,693 Location Charlottesville, VA May 21, 2023 #7 My BM brakes work well when towing my gator. Reactions: DavidBT and John Cooper
Mr. Bills Raconteur Emeritus Supporting Member Joined Nov 24, 2017 Messages 4,394 Location Area Code 605 USA & Código de Área 661 Mexico May 21, 2023 #8 I use an RVi3 brake system. I chose it after I started this thread on flat towing supplemental brakes: https://wranglertjforum.com/threads/flat-towing-braking-systems-your-recommendations-and-why.41511/ This was my "shopping list: for my flat tow setup: Sourced from e-trailer.com: Roadmaster High-Low Adapter for Tow Bars - 2" Hitches - 10 1/4" Rise/Drop 11-1/4" Long – 10,000# GTW 400# TW P/N RM-048-10 Roadmaster Falcon All Terrain, Non-Binding Tow Bar Motorhome Mount - 2" Hitch - 12" shank - 6,000 lbs. P/N RM-522 Adapter for Jeep D-Ring Bumper Mounts to Roadmaster Motor Home Mount Tow Bars 3/4" Thick P/N RM-035 7-Wire to 6-Wire Coiled-to-Straight Cord for Roadmaster Tow Bars 8' Long P/N RM-1676-7 CE Smith Tie-Down Bracket for Boat Trailers Galvanized Steel - Bolt On, 2 ea., P/N CE26214G [Used for safety chain attachment points on jeep] Roadmaster Tow Bar Cover P/N RM-055-3 [Unnecessary, but it allows me to keep the tow bar on the motorhome out of the weather Sourced on Amazon.com: Roadmaster 76" Single Hook, Straight Safety Cables 8,000 lbs P/N RM-645-76 [Also available from etrailer.com.] Sourced on E-Bay: Previously owned RVi3 Supplemental Brake System with Command Center and 6-tire Tire Patrol. Sourced locally: Magnetic Trailer Lights [already on hand in my trailer tow kit] Hitch pins and clips Miscellaneous hardware
