Not sure what I'm looking at here. Is it the red line graph?
Sounds like the baro reading is from before the throttle body. When you get off the gas and the throttle slams shut the manifold will pull vacuum but the turbo will still be producing pressure until it gradually slows down and bleeds off pressure, unless you have a blow off valve. But it "shouldn't" be a problem as most stock turbo cars don't had a BOV. Unless your tune isn't able to handle it.
How long does it take for the pressure to drop? Or does it just die? If you back off the throttle slowly can you keep it running and does the baro go back to normal?
This is a screen shot of the software from HPTunners. This is used to record a drive/run. The red line is the whole drive. I am trying to show that the graph (chart) has the recorded numbers for the Baro side of the MAP (in this case), with RPM and MAP manifold pressure.
As I mentioned, the MAP is in the stock location post throttle. Don't confuse the terminology, dodge has a 2 part MAP sensor, Manifold pressure + atmospheric outside pressure.
Yes I have a BOV and its a MUST, or the engine would run away and not idle, or make a detrimental turbo flutter sound. So pressure drops immediately. Not an issue.
The chart shows the numbers being populated all over the RPM and Manifold pressure (20= vacuum, 160= 7 PSI boost) so i know the one side of the MAP is working. 102kpa was taken from the KOEO state and maintains until i go into boost, then it carries that number all the way down into vacuum. This is strange to me, and Google can not help so far, as most people don't scan and record this. The Baro will return to normal only after I turn off the engine and restart, because this is when the PCM rechecks the baro level. I am on my 3rd sensor since my first sensor failed. Since the issue stays, im trying to look deeper and found this baro number situation... maybe its normal, and maybe its not an issue, no one can confirm this yet. So, if you have a turbo, a GEN3 PCM setup and you can take a reading of the baro, then reading can be compared.
I have been running with a turbo for 3 years and never had a post boost rough idle issue before.
I have don't a large check on every part of the jeep, and replaced EVERY sensor, but the lean, rough idle continues.
So i disabled the 02 sensors for the PCM stops trying to add fuel and really messing up my tune.
I know that my crankcase pressure (CCV) system was removed and used to go to a catch can, but it would fill with water very fast from colder winter weather.
Today I went out and purchased a PCV so I can once again hook my valve cover to the manifold (crankcase will have vacuum again) and keep my boost pressure from back filling into the crankcase. But since this baro number sticks and carries, im thinking that this new value is keeping my PCM thinking its in a boost state, and keeps adding fuel, even at idle, which is a big problem for idling... sometimes up to 20% more. This is the new issue... Other than making a better breathing crankcase.... also i am getting oil leakage from the pan gasket, which also indicates i have high crankcase pressure building. Which is why i was asking how he setup his crankcase balancing system on the turbo jeep in this chat, as I have to come up with something custom.
