Been a while since any updates. I've began work on my steering. The current pump whines, the steering is all over the place and my steering wheel can move several inches left/right before any reaction to the steering actually happens. My reman'd NAPA box that I installed several years ago is the culprit. The box is worn and needs replaced. The update is hydro assist. I haven't gotten very far. The hydro assist isn't the nearly bolt on kit from BMB, but something I've been piecing together over the last couple years. I'll admit, I have not saved any money this route. I should have gotten his kit to start. It is a fun learning experience to build your own though.
The first thing was shortening the psc ram. This is what Blaine does for his kit. This lets the ram fit a little easier on the axle side and the drag link. This is the 6x1.5 ram psc offers.
I pulled the currie steering out. I had a grease zerk which wouldn't take any grease.
I removed the zerk and fished wire thru to remove any debris. That didn't work so ended up shooting it with brake kleen and compressed air which did the trick. This also let me get all the old contaminated grease out. Next I want to put a bend in the drag to help with clearance. Its always been tight. I'll do this later at BFH Garage.
Next up, I removed the old steering box and pump. This was the NAPA reman'd unit from several years back. The new box is another saginaw that has fresh seals and has already been tapped for the HA lines. The pump is another stock unit that I picked up from Starkey when he switched to HA. I think I am going to modify the port on this one to allow for a little more fluid flow. If it doesn't work out or I dont like the performance, Ill give a psc a call.
Loosely installed the new power steering cooler. This is Blaines kit with the -8 fittings and hoses. This is where I ended. Ill pick it up again throughout the week and next.
To complete this still, I need new fluid, misalignment spacers for the ram, build my own drag link mount, mount the other PS pump and mount the tapped steering box. I still want to tweak the currie drag link, and I've also got a new heim joint and bushing coming for my metalcloak track bar
. The track bar has an obvious clunk that I can produce by hand.
