Any recs for a new radiator? Or is Mopar the only/best way to go? What about all aluminum radiators?
Got that spawn of Satan torx bolt out of the rear track bar only to find out that the bushing itself was rustwelded to the bracket. After trying to pull the trackbar out by hand with no success, I drilled a hole in the bracket so I could get it moving with a air hammer punch. That didn't get it to budge either. So, I sprayed Kroil and PB Blaster everywhere in that bracket I could get it into and left it to soak overnight.
Last night I got the idea of putting a bunch of odds and ends together to use as a puller to help the air hammer out by keeping pressure on the bushing from the other end. So, first thing this morning, I put this sketchy looking assortment of stuff out of my junk box together and started tightening it up. About the time it got tight, I felt it give a bit then tightened it up again and once it got tight, it gave some more and this I time I saw the track rod move in the out direction. So, I just used the "puller" to slowly get the track bar out.
The new track bar is loosely bolted up on the axle end now (with a new hex head bolt replacing the spawn of Satan) and tomorrow I'll bolt up the other end and tighten it all up. Here's a couple of pics of today's sketchyness.
No, but cleaning the cooling system might.raised highway coolant temp 8-10 degrees. It's a raised winch plate, would a flat one help with the temp?
Which fox shocks did you use? I've been looking at them but even with the ONX discount they're still 3x the price of the proven ranchos.
After flushing out the entire cooling system with tap water, I have done 4 flushes with distilled water. It is still coming out slightly brown. I'm guessing that the rusted out radiator is just continually leaching more rust. I will be doing 1 more fill with distilled water and then circulating it. After that, I'm not touching the cooling system until I get a new radiator installed. Then, I'll do 1-2 more distilled water flushes to get out the remaining rusty water. I'll put the thermostat back in, and fill it up with radiator flood at a 50/50 mix.
Anytime we have purchased a used TJ or XJ, we replace every part that is connected to the cooling system all at once. It is not that I am a genius and all knowing. It is because I learned that I do not like spending multiple weekends removing the same parts and hoses and swimming in antifreeze because the next part down the line has failed after replacing one component. By assuming that every part is a ticking time bomb waiting to go off at the most inconvenient time, I have improved my quality of life by a gazillion.
I've replaced the water pump, t-stat, t-stat housing, and radiator hoses. I'm replacing the radiator today. I will eventually replace the heater core but for now, I have bypassed the heater core.
Any other cooling system pieces I should replace?
