Have you had a chance to cruise on a freeway with those new gears?
I have 2 more heat cycles before I can cruise the freeways. I'll be getting those in tomorrow.
Mounted a flip down door stop on the inside of the tailgate to keep the tailgate from swinging closed. I believe there's a thread in this forum about doing this. It works very well.
My current list of leaks are this:
1. Valve cover gasket
2. Rear main seal
3. Transmission fluid pan
I plan on doing 3 this weekend. I could do 1 in the next few weeks. I have no idea when I'll get around to the RMS.
May I recommend doing the valve cover gasket first. Mine was so bad the underside of the engine & trans was an oily mess. Once I changed it and cleaned the residue I found that there were actually no other leaks.
There's dark red fluid on my garage floor right now. The transmission absolutely is leaking. I'm having some weird issues with the transmission right now and I heard that the 32RH transmissions have issues when the fluid is low.
Yeah, valve cover aint gonna fix that!!
Those look a lot like the tires I used to run on my old CJ5 back in the 80s. Great mud tires, not so much in sand though as I got stuck in my sandy yard with them. What brand and size are they?
36x12.5r15 TSL radials. I ran the same on my cj5 in the 90s. Mud, rocks, sand, snow. Never had a problem with any of that. That's why I have them on my TJ.
I ran the old Gateway Buckshots in Q78 15 and their Q78R 15 back in the 80's and early 90's.
Sure do miss buying 4 of them for $500.00 mounted and balanced.
These are what they have now. I just can't justify the price.
The TSL ain't cheap that's for sure. I ran a set of Buckshot Mudders on my first 4x4, a 76 fj40. That was back in the 80s.
Is it leaking from the connection to the cooler in the new radiator you installed?
My OBD II Serial Port Connector broke again. So, I order a new Serial Port Connector Pigtail and installed it today. Hardest part was removing the wire from the old one.
