I think the RAM mount is a 1" ball. I wonder if you got the 20mm ones by mistake.
It is the 1" ball mount.
Got a call back, found a burnt valve on my misfiring cylinder 3. Head job and check for cracked head time.
Very aero wallet soon.
I'm bored today. Sorry i'm spamming the htread lately, but it is what its for.
I took off the rusty front sway bar bushing brackets. I'm already going to replace the brackets. should I replace the bushings while I have the brackets off? They are fine so far.
EDIT: New bushings are $16 shipped from Amazon. They will be here on Friday.
Which ones did you get? The rubber ones will fall apart. I got the ones below.I'm bored today. Sorry i'm spamming the htread lately, but it is what its for.
https://www.amazon.com/gp/product/B000C57YQQ/?tag=wranglerorg-20
I haven't noticed any squeaking with mine, front or rear. I did install a set of sway-bar locks at the same time so there is no lateral movement in the sway bar. I have an AntiRock laying in the garage to put on the front. I'm throwing around the idea of changing the front bumper, so I haven't taken the time to put it on yet.I used those when I had the OEM sway bar and they squeaked a lot. Even with grease applied to them.
I put in Holley Retrobrights. I love the stock look only way brighter than the sealed candles.
I have the Rough Country floods and spots on my bumper. They are decent for the $70 price point.With my front bumper stuff, I am going to replace the stock fog lights with brighter lights. Any recs for $100 or less?
Trans leak:
New theory, I think the shift shaft seal is the culprit. I thought it was the gasket leaking, but the diagnostic foot powder spray was showing some red fluid above the gasket. Generally, because of physics and gravity, fluid doesn't flow up. I looked at the SSS and saw some red fluid coming from it. So, I cleaned that area off with brake cleaner and wrapped a shop towel around it. I'll check tomorrow to see if there is any trans fluid on the shop towel. If it is the SSS, I'm trying to decide whether I want to try to replace it again myself, or take it to a shop.
