Over the last few days, I ordered a
Dorman Transmission Pan with drain plug and
Dorman Nylon Gasket to replace the brass one that comes with it after reading reviews of people having leaks with the brass, but not the nylon. I also ordered an
Auto Meter 1/8 NPT bung for my trans temp sensor.
After tightening the drain plug, I let it sit about 72 hours with fluid in the pan while I waited for the bung to arrive. No leaks.
After the bung came in, measured and checked and double checked where I wanted to drill. The spot I chose ended up being between the bottom of the transmission body and the filter, drilled the hole and had a friend weld in the bung for me. Then I let it sit for about 36 hours with fluid in the pan again checking for leaks. No leaks noted.
Primed and painted the bare metal outside areas and reinstalled with my
Lube Locker LLT-A042 gasket. I wish I had thought to spray the outside of the pan with flat black paint instead of gloss, it would make seeing a leaking easier I think. Installed Permatex Ultra Black on the threads of the pan bolt that has the red paint on the end. Then reinstalled my Savvy engine skid.
Previously, I used a couple of those drain plug kits for the drain and the sensor. They were ok, but kinda big and bulky. The location I had put the sensor made it really close to the Savvy engine skid. Also, about a month ago when I changed the fluid and filter, the drain kit started leaking a little after putting the plug back in. Not from the plug itself, but the nut housing/gaskets that go through the pan. So far, this has fixed both of those issues.
Here's the previous setup.
