I ended up with the sound system upgrade and I may have got a bit amped up! It was fun learning how to match system components, how to tune the new amp I added and then the install went pretty easy.
Replaced the front dash and sound bar speakers with Polk 5.25" coaxial, added the sound pods to the front and packed the sound bar cavity with poly fill, ran all new heavy gauge speaker wire to all four corners.
The woofer never worked after the PO installed an aftermarket head unit and it was trash anyway so I dropped in a Kicker compact 8" sub in the console and turned the console into a sub enclosure using some MDF and packed it with poly fill. Didn't lose any storage in the console upper tray either, it just fit,
Then installed a Soundstream amp under the steering column by fabing up a little bracket where it rides horizontally behind the lower steering column panel where I can access for any additional tuning needed. Then swapped the head unit with a nice little JVC with a Sirus adapter.
I did good, this little fucker really bumps now! About all you want at 25% volume and it didn't crack during high volume testing. Never thought I would be doing a stereo upgrade and kinda scoffed at those that that was their first up grade, but the TJ is a capable 4 wheeler now and I wanted to do something to it this winter.
