deadbeat son
*sigh*
In my test I tried to be as fair and open as possible, with full disclosure of any alterations to the vehicle or issues. I wanted to find out for myself the truth about these fenders. I posted several times my own disclaimer that a lifted 33's would be more capable, that this is not an ultimate way to build for 33's, or the best or only way to do it. I also posted several times that 33's are realistically the largest you will fit on a stock TJ with these fenders, regardless of MC's claims, and the clearances will diminish with larger tires. I simply showed that it's a way to fit 33's on a stock TJ without having a degree in trig. How many times has there been a thread titled "Can I fit 33's on my stock TJ?" and a plethora of answers stating you need X lift. Well with X lift comes YZQK issues you need to resolve. Someone less experienced might figure it all out, or create a basket case jeep that never gets put together right or is an unstable hazzard on the road. If there is an alternative way to accomplish the same goal, namely fitting 33's on a stock TJ without messing with the suspension or steering, or some combination of fenders and springs, I'd want to know about it so I could make an informed decision about what's best for me and my requirements. That's the goal of the OP.
As far as comments about the appearance of the fenders, go nuts ye faceless usernames!
I care more about what my goldfish think of them.
I got the following takeaway from your posts. Please correct me if I got anything wrong.
If someone's goal is to run a 33x12.5 tire on stock suspension, they can likely do so with a combination of the MC fenders and approximately 1" of body lift (give or take 0.25").
Based on your observations, do you expect any of the results would change if fitting a 33x10.5 tire instead of a 12.5? For example, may a 33x10.5 potentially fit with the MC fenders and no BL? Or vice versa, may it potentially fit with the BL and stock fenders?
