Without checking the part numbers specifically, you didn't order 4 rear shocks, right?I guess I'll be joining the experiment...
I currently have Biltsten 5100s installed, so the Black max's will be replacing those.
Yes he did order 4x B8528 which is a rear shock part number.Without checking the part numbers specifically, you didn't order 4 rear shocks, right?
Looks like you better get on the phone quick and switch 2 of those rear shocks for 2 front shocks.I guess I'll be joining the experiment...
It has to be an improvement. Bilsteins ride like RC shocks.I guess I'll be joining the experiment...
That could be psychosomatic. I had new RC N3 shocks on my XJ with a 5.5" lift. I bought some Rancho RS5000X shocks and it rode so much better....until I got used to them a couple weeks later and then it seemed just slightly better.@Irun just swapped out similar shocks on an LJ and described it as a small, but noticeable improvement,
o snapWithout checking the part numbers specifically, you didn't order 4 rear shocks, right?
I was tired...
Where I noticed the difference is on bump and rebound. The BM shocks do a much better job of controlling them than the Rubicon Express (aka Bilstein) shocks. For example, when travel across railroad tracks or washboard roads I can hit them at higher speeds before the tail end will get loose. Also, I get more travel out of a shorter shock, so that helped with usable shock travel.@Irun just swapped out similar shocks on an LJ and described it as a small, but noticeable improvement, it'll be interesting to hear your experience. The Black Max shocks sound like a good option.
I'm betting you're going to like these. From my experience thus far, they produce a nicer ride on the TJ than the LJ. Not that the LJ ride is bad, but it is softer than the TJ. To be fair, I've got some control arm bushing issues with the LJ, so that may have something to do with it.Take 2, Thank you for your cooperation.
I currently have Biltstien 5100s installed so the Black Max's will be replacing those.
From what has been posted I think most people have received at least one bad shock out of the box. I know I did, but fortunately I caught it before installing.Is it me or are a lot of people getting bad blackmax shock’s ?
