Advice on steering kit upgrade
Irohk
St. Vincent and the Grenadines
I have 98 tj with a 2in lift on 31in tires, and I’m looking to upgrade my steering setup and was wondering what setup do you guys recommend.
I would really appreciate your insight on this.
Stock is great if you haven't bent the tie rod. If you have the ZJ tie rod is a good fix for bending the stock setup. There is no need to upgrade if you don't abuse things. Most Jeeps do just fine with the stock setup.
Reactions: Irohk and D M
ZJ is quite likely sufficient for your purposes. RockJock is the top of the line for stock axles. Those are your choices.
Yes but don’t forget the top of the line clamps you can get with the top of the line upgrade for the top of the line steering
The clamps are nice!
Okay thank you very much, I guess I'll stick with my stock for now and see how it goes.
