I have a question about flat towing my Jeep after having new gears installed. I recently had a shop change out the rear end in my Jeep. I bought my Jeep with Dana 30/35 axles , 4.10 gearing, and open diffs. I found a replacement LJ Dana 44 rear end that I purchased. I had the shop install the Dana 44, re-gear to 4.88, and install Eaton E-lockers in the front and rear.
By the way, my Jeep is a 4.0 with an NV3550 manual trans.
I hadn’t really thought about the new gear break in procedure. It really hadn’t even crossed my mind. So, I get to the shop to pick my Jeep up with every intention of driving my Jeep the 100 miles home. The shop owner asks how far I have to travel to get home and I tell him 100 miles, he says that I need to break the gears in by driving about 10 miles at lower speeds then to let the Jeep sit for an hour to cool off, then do that four more times. I know that is pretty standard break in procedure. He then tells me that since my Jeep is already set up with a tow bar, and I had driven a truck to pick the Jeep up, I could just flat tow it home. I could tell flat towing it was not his favorite idea, but since it would take me more than 7 hours to get home with “proper” break in, he said it would be ok. I insisted that if he thought it could damage anything that I would just drive it home doing the proper break in due to the giant pile of cash I had just spent on parts and labor. He informed me that flat towing it would be fine, so I did.
So, the question is…
Do you think I did any damage? Today I am doing a proper break in, even if it’s in vain. Everything seems just fine.
